need help with gear ratio sizes?
Old Mar 22, 2007 | 10:11 PM
buzzsaw714's Avatar
i have stock gears on 96 f150 xl sb sing cab.. and i got the 31x10.5x15's on it... i dont know what my gears are now or how to go higher.. ppl say go 3.71 or 3.55 to make it better performance but i dunno what i have now.. and lets say i want to change it.. how do you do so?
Old Mar 22, 2007 | 10:40 PM
StrangeRanger's Avatar
Start with basics. Look at the vehicle ID sticker on the door jamb. On the bottom 2 lines of the sticker are a bunch of codes. Look for the one that says "axle" under it will be a number like "17" or "19" or possibly an alphanumeric sequence like "H9." Post what it says. That way we will know what you have now.
Also what tranny?
2WD or 4WD?
Old Mar 22, 2007 | 11:54 PM
Bruce R Leech's Avatar
nice looking truck I like the way it looks with those tires. I have a 95 short bed 2x4 with 4.9 5 speed and I am running 235 75 15s and wanting to go to the size you have but I want to wait until I change to 3.27 gears. I have 2.73 stock and it is to high for those tires.
do they rub at all when you turn sharp if so I will go to the next size smaller.
there is a tag or should be on the diff. cover held on by on of the bolts. it will tell what should be in there.
Bruce
Old Mar 23, 2007 | 11:44 PM
buzzsaw714's Avatar
e4od tranny and its 2wd
Old Mar 24, 2007 | 12:25 AM
do they rub at all when you turn sharp? if so I will go to the next size smaller.
how did you do on your SAT test?
Bruce
Old Mar 24, 2007 | 01:05 PM
Steve83's Avatar
"Better" for other people isn't necessarily "better" for you. You don't need to regear with 31s, or even 33s. You only need to recalibrate your speedometer, which is easy to do in a few seconds totally free. That'll make your transmission shift properly again, and you'll see your old gas mileage again.
Old Mar 24, 2007 | 05:00 PM
csonka
Guest
Posts: n/a
I have 31 10.5 R15s and they do not rub at all.
