93 F150 4x4 shift pattern
Old Mar 2, 2007 | 05:35 PM
Dilligaf86's Avatar
Hello, my dad owns a 93 f150 4x4 with a 302 and auto trans, problem is his 4x4 shift lever broke and was removed before he bought it. I can crawl under the truck and change between 4wd low and 2wd hi. I am trying to find 4wd hi and was wondering where exactly it was. so basically my question is what is the shift pattern? Thanks for the help
Old Mar 2, 2007 | 07:12 PM
the 89's Avatar
the shift pattern should be 2 hi then straight down 4 hi then left down neutral and last down right 4 lo. this is from the shifter in the cab so it will be *** backwards from underneath!
Old Mar 3, 2007 | 08:14 AM
adrianspeeder's Avatar
That works for '88-'91, but '92-'96 have an improved sealed shifter linkage where the pattern is 2h, 4h, push down for N, and then 4l all in a line.
'89, even though you are moving the stick to the left, all it does is clear a shift dentant. The linkage still moves straight back.
This was replaced in '92 b/c of bein' prone to rust solid.
Dill, 4h will be one click right behind 2h. You are passing through 4h and N if you are finding Low.
Adrianspeeder
