1985 f150 problems
Old Feb 24, 2007 | 07:06 PM
boto's Avatar
1985 f150 problems
Posted: Sat Feb 24, 2007 3:18 pm Post subject: 1985 f150 problems Quote Edit Delete
I have the 302 (5.0) with efi and noticed fuel leaking out on the passenger side fender. found out that my fuel pressure reg. was bad and was leaking fuel into the vacume lines. I replaced the regulator and it still ran bad especially when a load was put on the engine. I popped the vacume line to the regulator and it was throwin out fuel. THANKS OREILEYS. I went and got a new one and just put it on and now its still running extremely bad. it will first start up real good and idle well until I put it in drive. after a few minutes everytime i stop the engine sounds like its bout to die and when i give it gas it does die or gets really close to it.
Also the engine was rebuilt not to long ago and has been running perfect til just now. secondly the transmission recently slipped on me so i immediately towed it home so i wouldnt damage it anymore and eversince then it hasnt slipped again? I had a friend look at it and he noticed how hard my gas pedal was and immediately brought up a tv cable or something. its connected to my tranny and then goes to where my throttle cable hooks up. he said there could be something hanging it up in the tranny.... dont know if the two problems could have anything to do witheachother im only a begginer mechanic on a low budget so im lost. any advice will help thank you.
Would a vacume leak cause this?
Old Feb 27, 2007 | 11:17 PM
89Lariat's Avatar
If the TV cable is out of adjustment or binding it will cause problems with the trans. Check that cable out ASAP before you drive it.
A vacuum leak will cause engine problems, fire it up and listen under the hood for one. Im not too positive on the older injected engines but if you do have a return line check it to see if fuel is flowing through it.
