Front Lower Shock Bracket stud broke.
On my 1995 reg cab 4x4 XL (aka manual everything) F150 with quad front suspension, the stud on the front lower shock bracket broke when I tried to take the nut off to replace the shocks.
What're my options to fix this? Does anyone (other than a junk yard) sell OEM style brackets? Should I consider upgrading to a solid front axle?
Help!
Help!
i had the same problem when i was replacing my shocks when i bought my new shocks it came with a replacement lower stud id asume most of them do all you have to do is drill out the old one and thread the new one in the new one comes with a nut to bolt it on but i recomend getting it welded
So the front shock of the quad shocks is the optional part? For some reason I thought the front was the mandatory shock and the rear was the optional. *d'oh*
Hopefully the shocks I bought (almost a year ago, blah) have the stud piece in the box.
Thanks for the help! Knowing the studs are available definitely brightened my day.
I guess these shock studs are in quite the demand. Dorman's "Help" brand sells them Part# 31001. Seems like it's just Grade 5 and not Grade 8 though.
http://www.partsamerica.com/ProductD...rtnumber=31001
Then it wasn't original. The factory lower shock bolt (F&R) since the early 80s has been a 9.8 w/18mm head & nut, and a half shank. In the late 80s, a point was added to make it easier to stab.
