coffee can like filter?
Old Feb 5, 2007 | 02:34 PM
hockeyfanjeff's Avatar
1993 f150 302, on the passenger side behind the battery there is a black can (kind of looks like a coffee can) with two small plastic hoses coming out, a black one and a red one. Is this part of the emissions system on these trucks? The red hose broke, (plastic was old and brittle) does the truck need this to run or how easily is it replaced?
Old Feb 5, 2007 | 03:28 PM
timack's Avatar
That's the vacuum reservoir...local parts store has vacuum line, splice in to the break. You could have issues with the A/C and/or defrost if you don't fix it...
Old Feb 5, 2007 | 04:37 PM
adrianspeeder's Avatar
Yup, ya would have vacuum problems with a leak. Some rubber hose should fix ya up fer a buck or two.
Adrianspeeder
Old Feb 5, 2007 | 05:07 PM
Exclamation Pics
just making sure everybody's clear on what it is....
and here is the break, unfortunately its right at a connector of some kind...
Old Feb 5, 2007 | 07:42 PM
$1.90 for 2ft of vacuum hose and a precision splice job got it done. Thank you timack and adrianspeeder
Old Feb 5, 2007 | 08:41 PM
timack's Avatar
Good work!, and you're welcome
Old Feb 10, 2007 | 11:14 PM
alloyking's Avatar
Haha. broke the same one. It should trigger the check engine light. I never noticed any driveability issues. But then again I dont have working AC.
I fixed it with some very slim shrink tubing. You know the plastic stuff you heat up and it shrinks? Just put the 2 ends in some of that and heat it up.
Or.. heck buy some new tubing. doesn't have to be the brittle plastic kind. rubber should work as well. You can get it at any auto/hardware store.
