1992 F150 4x4 Project Truck
I picked my self up a 92 F150, 302, 4x4 , Supercab(extened cab). Short box.
I plan put on a 3" body lift, I wondering If 33x12.50 will clear/ not rub on the stock rims?.
After i get everything all done all ill post up some before/after pictures. Might be the summer before its all done.
Ill Problemy Have Some Pictures by Tonight, The body not in the best shape. But The Price was Right. The body loose around two of the fenders, The one had a box/fender patch. The other is just half decent clean. Body fill will fix them for now, later ill get so aftermarket replacement fenders. There a small dent in the driver door which i should be abble to pop. Other then that, The front bumper has a rust hole in the top about 2" wide , the back bumper is twisted a bit(fixable). It has the chrome bumper and wheel package as well. Im going to get a light kit mounted them on the front bumper, one over that hole
, to cover it up. I'll tune up the engine with new plugs and wires, cap & rotor. Put a K&n air filter in, Change the fuel filter. Change the Pvc. Run some fuel treament stuff threw it. I think is going to run synthic-blend oil in her. Disconnect that air/pollution pump because we don't need it here. Highflow cats/ or gut them. And a highflow muffler. Then a 3" body lift. And some tires, 33x11.50x15 or 33x10.50x15 because they'll fit better on the stock rim then 12.50. And if im not broke ill get it painted.
