Squeaking clutch.
Squeaking clutch.
96 4.9L 80,000 miles: I'm getting a squeaking sound when depressing and releasing the clutch pedal. Not real loud but annoying. I had someone sit in drivers seat to push and release pedal while I was underneath to try to pinpoint the source and it seems to be coming from inside the clutch housing. I can also *feel* it by *touch* on the clutch hydraulic line from the housing to the clutch fluid reservoir. Any help appreciated!
pressure plate
Start by lubing the pedal shaft bushings (they're inside the tube for the brake pedal) & the lever-to-pushrod bushing. Click my signature link & look in the Hydraulic Clutch album for some diagrams & photos.
If that doesn't fix it, then the release (throwout) bearing is probably squeaking on the trans nosepiece, and you'd have to pull the trans (or the engine) to replace it. There's no sense in just lubing it, considering the work to get at it.
Thanks for the input guys. I may have misdiagnosed the source of the noise and will first investigate further based on the info about the clutch pedal shaft assembly. I found the R&R of this part on your excellent site Steve, thanks!
Running or off making the same sound. It's never real loud and changes in volume and even makes no sound sometimes. Tough one! Since I placed the original post I came across the info here re the clutch pedal shaft issue so I'm going to check that first and hope. Ideally it just needs some lube.
