1994 f150, front turn signal replacement &...
Old Nov 21, 2006 | 07:28 PM
ShorgasmIII's Avatar
headlight adjustment...
how to?
i figured the bulb would be a replace from behind like the headlights, but i cant seem to figure that out. i heard the cover needs to be removed, but see no screws.
and how to you do the H/L adjustment?
Old Nov 22, 2006 | 12:23 AM
Steve83's Avatar
The adjusting screws are those tiny hex heads. One sticks straight up behind the outboard end of the h/l, and can be seen in this diagram halfway between circles #11 & #1. The other points back, and is closest to circle #9.
To remove the whole assembly, you only need to remove screws #3 & nuts #2. If you only need to change the bulb, I think it can be done without removing anything. Just reach down in there & twist it so it can be pulled out.
