compression
Old Nov 14, 2006 | 12:16 AM
Atipsword's Avatar
compression
I have a 93 f150 with a 5.8L. I did a compression test because I have oil spraying from the breather and all cyllinders are around 125-130. Is this normal or bad.
Old Nov 14, 2006 | 06:46 AM
StrangeRanger's Avatar
Compression is OK.
Replace your PCV valve
Old Nov 14, 2006 | 10:32 AM
Atipsword's Avatar
I cant find specs anywhere on what the compression range is for that motor. Does anybody know?
Old Nov 14, 2006 | 11:50 AM
89Lariat's Avatar
I dont know the exact specs without looking, but that is fine. Since the readings are all very close there is no problem there, Id look at the PVC valve.
