2wd 6in. lift
Old Nov 6, 2006 | 04:23 PM
cobrasan's Avatar
2wd 6in. lift
Hello, new to this forum. I whant to lift my 95 supercab 2wd 6in. and was wondering about peoples experiences with this much lift. If the vehicle was still civilized and which kit was used. Thank you in advance.
Old Nov 6, 2006 | 05:14 PM
Ford4ever's Avatar
I had a 92 2wd at one time that i built to be a prerunner it had a 6" Superlift suspension lift and a Performance Accessories 3" body lift. It drove as good as it did before it was lifted, just make sure all your suspension and steering parts are in good shape and you have the truck realigned when you are done. Also be sure to use a quality lift kit that comes with all the drop brackets and a drop pitman arm to keep the suspension geometry where it should be. Your choice of tires will most affect how it drives, wide mud tires want to follow the ruts in the road and give you quite a bit of bump steer but a steering stabilizer eliminates most of that.
-Jon
Old Nov 7, 2006 | 11:08 AM
94f1504.9's Avatar
im running the same setup pretty much on my 94 but with out the body lift and it works great with 35's
