4.9 idle probles
4.9 idle probles
I have a 1990 4.9 straight 6. On startup the truck is missing, blowing smoke out the back and when left to idle dies. Once I drive the truck around and things heat up? I truck runs perfectly and at idle purs like at cat. Occasionally also the idle stays real high, do not know the rpm's without a tach, however I would say around 2k to 2500K. It is not throwing any codes. I have replaced the following:
IAC
Plugs
Plug Wires
Air Pump
What could I be missing. I seems like in open loop it runs horrible, however in close loop it purs.
Help!
IAC
Plugs
Plug Wires
Air Pump
Help!
IF the IAC plug/harness is unplugged/plugged in (while truck is off) and/or, if you suspect a poor connection (i.e. busted off tab on the harness), when, if ever, would/should you reset the computer.
Can you describe reset procedure?
The best way to reset the ECM is as follows:
1) Disconnect the negative battery cable
2) Turn the headlight switch on (this makes sure all the capacitors are drained)
3) Wait 10 minutes
4) Turn the switch off
5) Reconnect the battery cable
That resets it.
To properly "re-learn" the ECM, you then:
1) Start the engine and let it idle for 1 minute.
2) Turn it off and wait 10 seconds.
3) Restart it, and turn on loads, like the a/c with the fan on high, the high beam headlights, etc, and let it idle for 1 minute.
4) Turn off the loads, then the engine, and wait for 10 seconds.
5) Repeat steps 1-4, except with the idle at about 2000 rpms.
6) Take it for a test drive of about 10 minutes, driving aggresively.
That's it!
mine was the choke
my heat tube off the exhaust manifold to the choke broke off about 2 inches off the manifold. i was getting very lousy gas mileage and it really didn't like to idle cuz the choke was all the way on. it took a few minutes of driving before it evened out, but i was blowin smoke between gears due to it loading up. replaced the line and everything is fine. good luck
