Power Outlet 92 F150
Old Oct 11, 2006 | 06:29 PM
bamf_shadow's Avatar
My power outlet is not working, but my cigar lighter is. I checked the fuse first and it was good. Then I pulled the socket out and tested the blue/white wire for power, and there is none. I double checked the cigar lighter and fuse, they have power. Pulled the ashtray out and noticed a junction box behind it. From a visual standpoint everything looks in order. No loose wires or burned ones from what I can see. Anyone have a hint on this one? Thanks!!!
Old Oct 12, 2006 | 07:31 AM
subford's Avatar
It has its own fuse, fuse #9 is a Light Blue 15 Amp fuse. Fuse #9 is in the cab fuse panel.
Old Oct 13, 2006 | 09:13 AM
lurch241's Avatar
i have the same problum only the other way around my power outlet works but my cig lighter doesnt work not sure what is going on this is on a 93 f150
Old Oct 13, 2006 | 03:58 PM
RaWarrior's Avatar
If one's working, then just go to the auto store and buy a splitter for like $5 if you need multiple things plugged in at once.
My cig lighter doesn't work, but since I don't smoke I don't care.
