OBD Emission HELP
Old Sep 14, 2006 | 09:26 PM
Doc_Busa's Avatar
OBD Emission HELP
Hello, I could sure use some info on this one.
My '96 F150 XLT 5.0 (manual trans) has 110,000 miles. It runs perfect and I do my own work on it. Since I bought it three years ago, the check engine light has been an issue for me (even though it runs great). I got it smoged the past two times by clearing the codes. Today it did not pass, even though the check engine light was off.
I was told the OBD was not receiving signals from three systems. Previously, while the check engine was on, I took it to AutoZone, and they said they were not getting a signal from the OBD either.
I would greatly appreciate some leads so I can get this fixed. I have no $$$ for a dealership solution.
Thanks!!!
Old Sep 15, 2006 | 10:19 AM
projectSHO89's Avatar
Need the fault codes if any.... Can't guess.
That said, if you had recently reset the PCM (CEL), it takes a certain amount of time for the PCM to re-run all its readiness monitors. In the meantime, you will have an P1000 code. Since most emisssions tests now rely solely on the OBD-II system instead of a treadmill/sniffer test, the PCM must have all (or almost) of its monitors complete and passed. Sounds like you reset the PCM just before you went to the testing station. If so, you will need to drive it awhile to allow the needed monitors to run. This can be frustrating as is sometimes takes days, even weeks, for everything to run depending on your driving conditions and style.
Steve
Old Sep 15, 2006 | 11:17 AM
Doc_Busa's Avatar
Thanks. That's the issue though, no codes. BEFORE I reset the computer, AutoZone still could not read the OBD. That said, I searched and found an old thread about a fuse. Sure enough, the fuse was blown. I am heading to AZ this morning to see if they can now read the OBD.
Thanks again
Old Sep 22, 2006 | 05:30 PM
Doc_Busa's Avatar
OK, AutoZone checked it this morning. The issue seems to be OBD P0443 , which indicates a malfunction in the purge control valve of the evaporative emission system. AutoZone had no idea how to fix this and showed no purge valve in their parts list.
Any ideas would be greatly appreciated!!!
Old Sep 22, 2006 | 10:18 PM
A few portions from the factory diagnostic:
Diagnostic Trouble Code (DTC) P0443 indicates a failure in the EVAP canister purge valve circuit.
Possible causes:
-- VPWR circuit open.
-- EVAP CANISTER PURGE open.
-- EVAP CANISTER PURGE shorted to PWR GND or SIG RTN.
-- Damaged EVAP canister purge valve.
-- Damaged PCM.
l Key off.
l Disconnect EVAP canister purge valve.
l Key on, engine off.
l Measure VPWR circuit voltage at EVAP canister purge valve harness connector.
l Key off.
l Was voltage greater than 10.5 volts?
Yes
GO to «HW2».
No
REPAIR open circuit. RESTORE vehicle. COMPLETE PCM. Reset to clear DTCs. RERUN «Quick Test»
HW2 CHECK EVAP CANISTER PURGE VALVE RESISTANCE
l Measure EVAP canister purge valve resistance.
l Is resistance between 30 and 90 ohms (vehicles with test pin 67) or 30 and 38 ohms (vehicles with test pin 56)?
Yes
For Escort/Tracer, Mustang, Thunderbird/Cougar, Ranger, Aerostar:
GO to «HW3».
All Others:
GO to «HW4».
No
REPLACE damaged EVAP canister purge valve. RESTORE vehicle. GO to «HW42».
The CANP valve is located in the vacuum line between the throttle body/intake and the charcoal canister. On your truck, IIRC, it's on top of the engine near cylinder 1.
Steve
Old Sep 23, 2006 | 12:35 AM
Doc_Busa's Avatar
Thanks a ton Steve, I will check this out tomorrow. It is started it make me think though, there have been a few occasions when I start the truck up and the electrical goes crazy. The turn signals don't work, all the dumby indicators are on (i.e., ABS, check engine, etc.). I turn off the truck, wait a second, turn it back on and everything is fine... I hope I can find out where the issue resides tomorrow.
Thanks again!
Old Sep 23, 2006 | 03:32 PM
Doc_Busa's Avatar
OK, I took a look around, but it is still rather confusing. One immediate find was a disintegrated vacuum line coming off the throttle body. It was coming from a nipple on the TB that connected to a lone plastic tube that connected to a black box near the fire wall. I think this "black box" is connected to the carbon canister... Is the carbon canister located below the battery (and off set towards the motor)???
Could this line being torn cause the check engine light? I disconnected the battery to reset the PCM. I hope this works. How long should I wait until I try to have it smoged again?
Thanks!!!
