leaky oil pan
Old Sep 20, 2006 | 11:16 PM
GTRider245's Avatar
If it is that little of a leak I wouldnt even bother fixing it.
Old Sep 26, 2006 | 10:25 PM
jeff22's Avatar
Well, I Jb welded it. Looks like everything is good for now. It's been two days and no leak. It still leaks a little around the drain bolt, not sure quite how to fix that. I put a new bolt in and teflon washer. Hopefully it will hold up for a few years and I won't ever have to worry about replacing the pan.
Old Oct 16, 2006 | 10:46 PM
Bruce R Leech's Avatar
Originally Posted by jeff22
another question, just getting around to really going over this truck.
I have a leaky oil pan, it appears that it is rusted in some areas and I think that the oil is seeping out of one of the rust spots on the pan. I'm not exactly sure how an oil pan rusts out, being that it is filled with oil. It's definitely not leaking from the gasket.
I originally thought that the oil was coming from the bolt, so i bought a new bolt with the washer and put that on today and cleaned off the oil pan. The leak appears to be coming from just above and a little to the left of the bolt.
Is there any way to fix this without replacing the oil pan? I'm not really that mechanically inclined how much will it cost to have a shop put on a pan if there is no other way to fix it. It's just a small leak and i can live with it i guess, but it's making a mess on the road where i park it. It's a 93 f150, 5.0 liter, 4x4.
drain the oil and clean with thiner and rugh up with corse sand paper use JB weld it will outlast the rest of the pan.
Old Apr 20, 2008 | 03:53 PM
a1moldmaker's Avatar
double
Old Apr 20, 2008 | 03:54 PM
Originally Posted by kretinus
According to the Ford mechanic who replaced my pan, you should not have to remove your intake manifold. I can email you the procedure he gave me if you want.
kretinus,
i am currently changing the oil pan on my 94 f150 supercab
and was wondering if you could send me a copy of the procedure sheet you have
thanks
Old Apr 20, 2008 | 05:15 PM
sorry
