hmmm, the selector valce has been replaced before, is there any known problems with them? could it be cause the fuel bleeding back into the tank problem also?
NO, as I said above the check valve is in the HI-Pressure Fuel Pump. If the system does not hold pressure for a while after it is shut down then you have a bad Fuel Pump on the frame.
