92 w/302, whats this wire go to???
Just bought my 92 F150 w/302, and the PO just installed a rebuilt longblock. I was poking around under the hood and I discovered a two wire connector that is unplugged. I searched around and couldn't find where it might go. The connector is located on the right side of the engine. There is a large harness that runs behind and slightly above the power steering pump, and this 2 wire harness splits off of that just before the engine. It is prolly 12-14" long, and has a clip on it that secures to a spark plug wire fairly well. The connector itself looks a lot like the connectors used on the injectors. Anyone got a clue on this one? Thanks!!!
Originally Posted by bamf_shadow
White w/Red stripe, Yellow w/Green stripe. I ran my hands all around the power steering pump, didn't feel any connectors, just the two hoses.
Yellow w/Green stripe, Power Steering Pressure Transducer to EEC Module.
By the way, the Power Steering Pressure Transducer is by the Steering Gear Box close to the Radiator.
Hmm, I flat out don't have a connector there. All there I have are the 2 hoses. I pulled back the plastic shrowd and all that was under it was the ujoint. Maybe someone swapped the steering or something?
