Leaking Transmission and Exhaust Question
Old Jun 21, 2006 | 01:11 PM
twarf's Avatar
I have a 95 4X4 with a 302 and a 5 speed. The transmission has a leak and I cannot figure out where it is leaking from. I see fluid on the crossmember and on the bottem bolt that holds the transfer case to the transmission. I just can't tell exactly where it is coming from. Any ideas?
Also I am thinking of installing a Flowmast catback system with a 40 series with single inlet dual outlet. Has any one done this and how do they sound?
Old Jun 22, 2006 | 12:55 AM
Ford4ever's Avatar
The output shaft seal could be causing a leak between the transfer case and trans. Clean it off with some brake clean, drive a couple miles and see what it looks like.
Flowmaster 40 series sounds awesome with a 302.
-Jon
Old Jun 27, 2006 | 08:03 AM
twarf's Avatar
I found the transmission leak. It is coming from the top shifter plate. It looks like there are 3 rubber plugs on the back of the top shifter plate. It is either coming from there or the actual top plate itself. I hope the dealer sells those plugs in case it is those. I am just happy I found the leak.
