1995 F-150
Old Jun 13, 2006 | 04:30 PM
rvogster's Avatar
1995 F-150
Ok, so I'm looking to get a truck to haul parts around and occasionally my 92 mustang. It will probably be a daily driver also. I found a 1995 F-150 with 4.9 I6, E4OD, 3.08 rear gears and its 4x4. The body is in good shape but there is some rust on the underside, the A/C works and it seems to run good. It has 122,000 miles on it. They want $6000. Is that to much?
Old Jun 13, 2006 | 04:36 PM
NCCamper2003's Avatar
If I ever want to sell my '95 F150 XLT (5 L w/3:08 gears; 227,000 miles; body in good shape - no rust), if I were to get anywhere near $6000, I would be thrilled! In other words, that may be on the high side for the F150 you described. Have you looked at the book value?
Good Luck!
NCC
Old Jun 13, 2006 | 04:55 PM
rvogster's Avatar
Hmm, I guess your right. KBB puts it at about $5000 but that is in excellent condition and this truck is not in excellent condition.
Old Jun 14, 2006 | 06:34 PM
StrangeRanger's Avatar
You do NOT want 3.08 gears in a tow vehicle. Look for one with 3.55s
Old Jun 29, 2006 | 12:15 PM
rvogster's Avatar
Ok, I ended up getting a different F150 for less but it is very similar. So now the question is what do I need to do so I can tow 5000 pounds every once in a while? I figure 1800 for the open trailer and 3200 for the mustang. Since it’s a 4x4 I will have to pay to upgrade both sets of gears so how much is that going to cost me? I will also need to pick up a hitch and have it installed on the frame. Will I need to do anything else? Like upgrade the suspension?
Old Jul 1, 2006 | 03:55 AM
PKRWUD's Avatar
It all depends on the engine/trans/gears combo. If your "new" truck has an auto tranny and a 4.9L engine, and is a regular cab, you'd want 3.55's. Your Max GCWR would be 10,000 lbs, and your trailer could be as much as 5600 lbs.
