daystar installed
Old Jun 8, 2006 | 11:18 PM
bmx150's Avatar
daystar installed
i just finished installing new 2" spacers and coils, the only thing is teh front end now angles in the front tires angle in alot how can this be fixed?
-dan
Old Jun 8, 2006 | 11:52 PM
rolsmojave3's Avatar
Alignement shop would be my guess
Old Jun 9, 2006 | 09:33 PM
Jrpotts01's Avatar
Hello,
The only thing thats going to fix it is a set of Axle Pivot Drop Brackets. They can be purchased from jcw.com
Old Jun 10, 2006 | 01:59 PM
GTRider245's Avatar
Originally Posted by Jrpotts01
Hello,
Or not. Adustment cams will probably fix the problem, consult your local alignment shop.
And anyone who buys axle drop brackets from JC Whitney is an idiot.
Old Jun 10, 2006 | 09:28 PM
Ford4ever's Avatar
Increasing the front ride height changed your front camber, and camber changes toe, which is how far your tires point in or out. The correct way to get your suspension angles back in spec would be with drop axle pivot brackets, radius arm brackets and a drop pitman arm, basically a full lift kit. The cheap way to do it would be to buy camber adjustment sleeves and have the truck aligned. The camber sleeves may or may not give them enough adjustment to get the camber back in spec, but they can get it close and then adjust the toe so that you won't wear out your tires.
-Jon
Old Jun 10, 2006 | 10:48 PM
GTRider245's Avatar
Well I guess it really depends on what he really used. He says he used a coil and a spacer, which would give 4 inches of lift, in which case he WOULD need the drop brackets. If just using one or the other you can get away without them.
Old Jun 11, 2006 | 11:56 AM
Ford4ever's Avatar
Thats true, i didnt catch that at first, yeah you would definitely need all the drop brackets to get that thing to drive right if you lifted it 4".
-Jon
Old Jun 14, 2006 | 09:38 PM
bmx150's Avatar
i bought replacement coils from autozone made for the truck they were just one rung higher ( bout 1") total lift was around 3", wish i measured, does anyone have the front height for a 95 150 4x4 regular cab longbed, 4.9 with 31x10.50"s.
-dan
Old Jun 15, 2006 | 10:00 PM
Ford4ever's Avatar
Either way you need an alignment at the bare minimum, the tech that does the alignment should be able to tell you what you need to do from there.
-Jon
