fuel pump
Old May 30, 2006 | 01:42 PM
mikelac's Avatar
fuel pump
i have a 1986 F. 150 4+4 dual tank yesterday it stall out trying to load it on a trailer it sounded as if it ran out of gas so I switched to the rear tank which was full it would not start I’m still trying to start it today it has a pump on the frame and I understand A pump in each tank I can hear the pump on the frame turn on and shut off supposedly with pressure but if you disconnect the lines there is no gas Could not find a bad fuse not sure if the pumps in the tanks are working. I had been using my truck at the hunting camp all day With no problems when I started to load it on the trailer I got the front tires on and it stall out and had to load the rest with the winch anyone have any ideas?
Old May 31, 2006 | 09:22 AM
PKRWUD's Avatar
Check the fuel pump relay. Should be under the hood.
Old May 31, 2006 | 10:43 AM
mikelac's Avatar
fuel pump
you are not going to believe this i talked with a couple of my friends and they said try putting more gas in the front tank and guess what it worked. i could not believe that was all it took . when the front tank ran out it lost prime . so a good ending for me.thanks for the input
