bad anitfreeze problem
Old May 11, 2006 | 10:23 AM
inline6dude's Avatar
Ok well i have another problem again, i just had a brake job done in the front, now i'm having more problems...ok well i'll give the whole story...in like february my heater core went and i was leaking fluids, replaced both rad hoses, had bypassed the core (for now)....well i'm still leaking and its gotten really bad in the last few days. it's pouring out a quart of two whenever it wants usually sitting for a while or being parked after ran... it gets sluggish sometimes also,usually 1st/2nd...well what do i do ...? i was told it was the water pump...what else could it be????its leaking alot from all over,sometimes it doesn't leak.....well anyway would this pump fit, its from summit i just want to know it if fits before i buy it...heres the address at the bottom.........thanks for the help eveybody
http://store.summitracing.com/partde...5&autoview=sku
Old May 11, 2006 | 05:00 PM
Jrpotts01's Avatar
I had a very similar problem with my F-250 with 5.8L. After I shut off the truck and let it set over night it would have a small puddle of coolant under it(comming from the back of the engine). After hooking up a pressure tester to locate the leak, I thought it was a rear freese plug. I couldn't see at all behind the flex plate. I later used a mirror and discovered it was comming from the back of the lower intake manifold. Hope this isn't your problem.
Old May 14, 2006 | 01:04 PM
well i climbed under and its leaking from the weep hole by the lower hose, will that pump fit from summit....?
Old May 17, 2006 | 01:21 PM
kretinus's Avatar
It should, but you'll need to call Summit to make sure.
Old May 17, 2006 | 02:18 PM
ONELOWF's Avatar
Summit has a great feature you should try. You can search by vehicle model and engine type. Try that. My guess is that you can tell what you've got better than anyone else, I mean its sitting in front of you.
Old May 17, 2006 | 02:55 PM
thanks for the help guys...i'll post back if i have any more problems...
Old May 20, 2006 | 10:50 PM
Tiwsted's Avatar
Red face
i have the same truck and have had the same problem, what worked for me was just simply replacing the water pump...hope that helps
