No Fire---help!!!
Old Apr 18, 2006 | 10:31 AM
rednckbill's Avatar
Exclamation No Fire---help!!!
HELP!!! BOUGHT A 93 F-150 5.8L. Drove 1 week. Started truck one morning,idled for about 2 min. then died, upon investigation,discovered NO spark. Replaced ignition coil,distributor,ignition module, and ignition switch. Still no spark. I have 12 volts to coil, 12 volts to all fuses (under hood and dash) Ran self check ,no codes,( but I did have battery disconnected during ignition module replacement..) NOW WHAT DO I DO??? PLEASE HELP!!!!!!
Old Apr 19, 2006 | 11:07 AM
rednckbill's Avatar
If anybody has even the slightest clue what else i can try now puh-lease LET ME KNOW I am about ready to get out my shotgun and put this truck out of it's misery if I can't figure something out soon have been trying to fix it just about every evening for the last 3 months and it still doesn't work
Old Apr 20, 2006 | 11:16 PM
PKRWUD's Avatar
Hook up a 12v test light between the neg battery post and the neg side of the coil, and have someone crank over the engine. What does the test light do?
Old Apr 28, 2006 | 12:00 PM
satchmo1953's Avatar
You might check the wires from your ignition switch to the coil and from the coil to your dist.
