Need a step by step of how to replace headlight lens?
Old Apr 12, 2006 | 12:24 AM
TheGrayt1's Avatar
Did not find instructions in ym manual. I am replacing the drivers side on my 92 f150, and did not see any bolts, and dont know how it comes out? Can soemone help me out...
Old Apr 15, 2006 | 12:58 PM
daniel3312's Avatar
From: Osceola Arkansas (50 Miles North From Memphis TN)
I'm not sure i've never had to take one out but did have one replaced only reason i didnt do it myself is it took them a few extra days to get it in so they said they would install it free. But I remember looking at it and i know you have some screws at the top and some under it..
Good Luck
Daniel
Old Apr 22, 2006 | 12:53 PM
GTRider245's Avatar
There is an exploded veiw of the whole front end in any Haynes/Chilton's Manual. I have found the Chiltons more helpful for things such as this.
1. Unscrew both screws holding the chrome/grey bezel to the header panel.(You can see the screws when you open the hood.)
2. Unscrew the nuts that hold the whole turn signal/corner lense/bezel assembly to the header panel. (They may be hard to get to, they are right behind the turn signal between it and the core support. There should be two.)
3. Pull the assembly out and unplug the turn signal bulb, side marker bulb and corner light bulb.
4. Now you should just be left with the headlight. Three clips hold it on at the audjustment screws. You should be able to see them.
Hope this helps.
