headlight dimmer switch
Old Mar 29, 2006 | 09:28 PM
bmx150's Avatar
how is the headlight/dimmer switch removed, i have a 95 with a few dead bulbs and cant fiure out how to remove this switch it seems bolted on...thanks for the help.
-dan
Old Mar 29, 2006 | 10:40 PM
daniel3312's Avatar
From: Osceola Arkansas (50 Miles North From Memphis TN)
Are you referring to the **** or the actual switch?
Old Apr 1, 2006 | 08:59 PM
bmx150's Avatar
the **** it has a slot on the bottom when pulled out is this part of the removal?
-Dan
Old Apr 2, 2006 | 11:36 AM
PKRWUD's Avatar
Yes. You need to stick an o-ring pick into the slot, and pull it towards you. This will release the tension spring that holds the **** onto the shaft.
