EGR Check
Old Mar 29, 2006 | 07:54 PM
daniel3312's Avatar
From: Osceola Arkansas (50 Miles North From Memphis TN)
EGR Check
Hey, while im waiting for my fuel pressure tester to arrive i was doing alittle investigating on the truck my question is Unplugging the connector to the egr or removing the vacum line from it, should it make a difference in the way the truck runs? The reason i'm asking is when i unplugged one and then the other it had no affect either way. But it did seem to idle just slighly higher and run just a tad bit better with my finger over the line.....
Daniel
Old Apr 1, 2006 | 06:48 PM
PKRWUD's Avatar
The EGR valve shouldn't have any effect on performance or idle because it's only used during part throttle. If it does make a difference, then it's not closing all the way, and needs to be replaced. Eliminating it is a bad idea because it helps keep cylinder head temps down.
Old Apr 3, 2006 | 09:12 AM
daniel3312's Avatar
Thanks man id never consider eliminating it just wanted to be sure it wasnt causing any problems.
Daniel
Old Apr 3, 2006 | 10:02 AM
PKRWUD's Avatar
Daniel
Sorry, I'm just used to people trying to find an excuse to remove it.
Try pulling it off and cleaning it up before replacing it. There may be a small bit of carbon that is preventing the valve from closing all the way.
