Clutch problem
Old Dec 9, 2005 | 06:03 PM
RoushRich's Avatar
Clutch problem
I have a 1995 4x4 f150 with the 5.0 v8. It has been sitting for about 3 or 4 weeks. the clutch is stuck on the floor and i was told it has air in the line. How do i get the air out or could it be something else. Any help would be greatly appreciated.
Old Dec 10, 2005 | 01:42 PM
topgun3208's Avatar
It's basically like bleeding brakes. fill the clutch reservoir, pump the clutch, have someone underneath to crack the bleeder valve to expel fluid. repeat this procedure until u get a "good" pedal
Old Dec 10, 2005 | 01:55 PM
Clifford f150's Avatar
might i suggest doing a search...especially in the transmissions forum. This is one area which hasn't changed much (if at all) in these trucks.
a couple of threads that I found, might be useful to you:
https://www.f150online.com/forums/sh...utch+Hydrolics
https://www.f150online.com/forums/sh...t=Clutch+floor
I was looking recently at bleeding my clutch too, but more as a preventetive maintenance type thing.
