1985 f150 Brake light on
Old Aug 3, 2005 | 09:35 AM
kaolin2's Avatar
I have a brake light that stays on, started yesterday. The owners manual says to take the truck in, something has failed in the brake sysytem.
Where should I start looking? Any ideas?
Old Aug 3, 2005 | 12:30 PM
Clifford f150's Avatar
the obvious answer is to check the parking brake, make sure it is not on...sorry, I know it's obvious but sometimes those are the ones that get ya... Might also make sure the plunger switch on the parking brake is operating...it can get stuck, a little wd40 will free it. If that's not it I'd then check the master cylinder, make sure the fluid level is ok, do a visual inspection around it and the wheels, see if you see any leaks. Pay special attention to the rubber hoses. After that, I'd start thinking master cylinder might be bad-- but there are usually some other symptoms (like a squishy pedal)....any other issues?
Old Aug 8, 2005 | 08:15 AM
PKRWUD's Avatar
Are you talking about a warning lamp on your dash, or an actual brake light?
