1988 5.0 L pinging badly and low power
Old Jul 5, 2005 | 09:02 AM
cleat's Avatar
Unhappy 1988 5.0 L pinging badly and low power
I am working on a 1988 F-150 lariat 5.0 L. The following have been checked and/or replaced. plugs, wires (wires are in correct order), cap, rotor, dist and module, coil, no codes showing, TPS, IAC, cleaned throttle body, all filters, good fuel pressure, power flushed injectors, ignition timing 10 degrees spout unplugged around 25 degrees spout in, MAP. Nothing dragging, I can push the truck by hand easily. Not running hot at all.
Any more ideas ?
Old Jul 5, 2005 | 09:57 PM
92f150302's Avatar
whats the L you put after 5.0?
Old Jul 6, 2005 | 06:06 AM
cleat's Avatar
Litre
Old Jul 6, 2005 | 12:14 PM
92F150S/C's Avatar
Did you do a compression check on the engine. The pinging sounds like you might have carbon build up on the top of the piston or vavles. Id check the compression first. How many miles are on the engine.
Old Jul 6, 2005 | 05:05 PM
ckm's Avatar
ckm
How is the exhaust system on your truck. I had an e150 in work that did the same thing and the catalytic converter was blocked partially.
