Lifting a 95 2 WD
Old Apr 27, 2005 | 12:48 AM
jonk37's Avatar
Lifting a 95 2 WD
I need to lift my 95 F-150 Eddie Bauer 2WD truck with 31" BFG's. I do a little offroading in the desert in AZ and I hate hitting rocks because my front end is so much lower than the rear. Honestly I'd like to have it sit a little higher in the front than in the back, but it isn't that important. I've read that when you lift a 95 even 1.5" that it will cause camber problems unless you get an alignment kit, but I can't find this alignment kit, sold by itself, anywhere. It seems like Tough Country makes a semi decent 2.5" Kit, but it has a bunch of brackets and I've had extremely bad experiences with brackets like these in the past. I've heard that you can just slap on some F-250 springs and it will work fine without any other adjustment, but I've gotta still believe its gonna screw with my camber. Any ideas?
Jon
