'96 302 Won't Start When It's Wet/Damp Outside
Old Mar 24, 2005 | 08:53 AM
bktoney's Avatar
Question '96 302 Won't Start When It's Wet/Damp Outside
My 1996 F150 will NOT start when its raining, damp, or just wet outside after sitting for a few hours. It starts every time when it dry. It acts as if it isn't getting any fuel, or no spark. If it has been running, and it starts to rain, it will start up, but not if its been sitting for a few hours or overnight. Anyone ever run into this?
Old Mar 24, 2005 | 12:06 PM
bigbronc's Avatar
A cracked distributor cap would cause this. Condensation forms on the inside of the cap and won't allow the voltage through the rotor button. Next time it happens, pop off the cap and spray some wd40 inside. This will dry out the distributor. If that doesn't work, repost with some more info.
Robbie
Old Mar 24, 2005 | 05:17 PM
Ford4ever's Avatar
The spark plug wires are probably dry rotted and arcing. Do a full tune up, Cap, Rotor, Plugs, and Wires and your problem will be solved.
-Jon
Old Mar 25, 2005 | 04:21 PM
colvin's Avatar
yep tune up time, but if you want to investigate on a dry day start your truck and take a spray bottle and spray the cap and wires one by one and try to find the problem...
Old Mar 26, 2005 | 03:21 PM
bktoney's Avatar
OK, guys...I now have a new dist cap, button, wires, and coil. Still having the same problem.
Old Mar 30, 2005 | 08:51 PM
beastie's Avatar
Does it throw and codes?
Old Mar 31, 2005 | 07:53 AM
bktoney's Avatar
Nope...NO codes at all!
Old Apr 1, 2005 | 09:45 PM
92f150302's Avatar
don't drive it when its wet
