Fuel pump
Old Apr 14, 2004 | 07:09 AM
bucket's Avatar
Fuel pump
Shopping for new fuel pump. Do pump's come with sending units, 1992 300 2 tank setup. Dont need pump right away so i can look for good price.
Old Apr 14, 2004 | 06:46 PM
cleat's Avatar
Smile
They do not come with sending units, however if you buy a ford pump it will come with the entire unit which goes into the tank. If you live in a rust prone area this is a factor as the original lines coming out of the tank are likely very rusty. NOTE: Ford decided to do a wiring chang in the later models of our body style and the new pump will come wired this way. You must then buy the proper pigtail from Ford and rewire your pump connector. It's not all bad however as this is a much nicer plug. I had to do this on my '93.
