77 f-100 brakes
Old Mar 21, 2004 | 07:05 PM
sleeve's Avatar
77 f-100 brakes
Hey does anyone know what is involved in changing the manual brakes on a 77 f-100 2WD, no cruise, front disks from manual to power? Will the old master cyliner and pedal and bracket fit or will these need to be changed. Thanx in advance!
Old Mar 26, 2004 | 04:38 PM
7283-250's Avatar
I am not positive but I beleve you would need the break booster (the big round canister that the master cylinder bolts to).
As for using you current master cylinder I do not know but new master cylinders will run about $20 (my 83 did).
you may be able to use your current pedal but again I am not sure.
Run to a salvage yard and check some trucks out and see what you can find and check all the mounting points. If your lucks there may still be a '77(or similar year) kicking around in some salvage yards with power breaks.
Old Mar 27, 2004 | 12:26 AM
Nite351's Avatar
I'm not positive on this, but I do believe you should be able to keep your pedal but the last time I did that I had to change the rod from the pedal to the booster and I am almost positive I had to use the master that belongs on the booster.
Old Mar 27, 2004 | 07:21 PM
Ford4Fun's Avatar
I have been looking at the hydo boost system on the superduties. It is powered from the power steering pump, you need 1 line out and 2 return lines into the resivoir. It would give you power brakes if you later decided to go with a big cam that doesn't produce vaccume. I am not sure of bolt mounting width and the piece is spendy ($300+) from the dealer, then you would need a new master cylinder. I have been looking for my mustang.
Old Mar 28, 2004 | 06:17 AM
sleeve's Avatar
Thanx guys. I've been looking around and found a guy with a 78 booster and 79 booster both with the MC. They don't look the same and am still not sure if they will fit the 77. Anyone have a Hollaner manual to check?? Thanx again.
Old Oct 25, 2010 | 08:30 PM
1974F100's Avatar
I am wanting to do this same thing on my 74F100. Have you had anymore luck with it ? Sounds like you are a couple steps ahead of me on the same project.
