changing parking lights-help
The screws on top are self explanitory.....
The 2 nuts on the bottom are more challenging. To start, the passenger side, take out the battery, unless you like hurt hands, there iare 2 holes in the rad support. In there is 2 11mm nuts. A 11mm deep 1/4 inch drive socket with a 3in extension works good. Take them out and take the parking light assembly ouy. The headlight doesnt come with it. Just twist to remove the light sockets.
Same for the drivers side. You may have to fight with the washer/overflow bottle. If you do just take it out..... Whatever it takes to make your job eaiser.
