Air conditioner help please
Old Nov 20, 2003 | 03:23 PM
Wapiti's Avatar
My A/C just stopped. The fuses are all ok, but the compressor wont kick on when I turn the **** to a/c. The wires are all in place. Any help would be great.
Old Nov 20, 2003 | 03:35 PM
beastie's Avatar
Mine recently did the same thing. I would say you are low on freon (sp?) and the pressure is too low so it is triggering the pressure switch on the inside so it wont come on. Easy way to test is to connect a wire straight from the compressor to the battery, and if it kicks on....ur low on pressure.
Old Nov 20, 2003 | 07:57 PM
FORD302GUY's Avatar
I would jump across the low pressure cutout switch rather than jumping directly to the battery. (The switch I am referring to is right by your reciever/drier.)
Old Nov 20, 2003 | 11:47 PM
dave186's Avatar
isnt it a bit cold for AC this time of year?
Old Nov 21, 2003 | 02:13 PM
Wapiti's Avatar
Colorado is still a little warm, but mostly I am thinking about next summer!
I will give your suggestions a try. thanks
Old Nov 21, 2003 | 11:56 PM
bigreds2005's Avatar
I was just going to say that
you got to move to Michigan where its cold gosh i love that white stuff what is it SNOW we need it
Old Nov 24, 2003 | 03:24 PM
Hit Man X's Avatar
If you have checked everything, you are probably low on refrigerant. I'd just get one of those cheapo $5 testing guages to give you an idea of the pressure in your system.
Is the A/C system totally stock in your truck? If so you may have a leaky hose, bad o-ring, or band compressor seal.
Old Nov 24, 2003 | 06:21 PM
Wapiti's Avatar
Yeah, it is stock, but I doubt it has been serviced for a while. I got it used a year ago. It snowed yesterday, so I am not very motivated to work on my ac anymore. It will be a good springtime project.
