Its Fixed !!!
Old Oct 7, 2003 | 07:01 AM
KB ZILLA's Avatar
Roller 302 in 87 Truck Saga now over.............
Just wanted to let everyone know that I finally fixed the problem
Now it idles very high. it will idle about 1500 rpm. then when you put it in gear it will just die unless you give it gas, then runs really rough.
It was the throttle body that has been causing all of my problems. I pulled the throttle body from my other 87 truck and installed it on this truck and it solved all the problems.
To make sure it wasnt a fluke, I installed the bad TB on my good truck and it had the same symptoms.
Oh....I also wanted to let you know that I am running the stock 87 truck computer, wiring, and fuel injection setup on a 90 Mustang roller shortblock!!
The truck computer runs smoother than the Mustang computer.
So no you dont have to change computers!!
Thanks for eveyones help!!
Old Oct 7, 2003 | 04:11 PM
blksn955.o's Avatar
Glad it worked out for you.
I can not wait to swap in a stock GT cam (along with some 1.7rr) and see the diff.
let us know on how it drives and were/how the power seems to be.
Old Oct 7, 2003 | 07:01 PM
inski21's Avatar
Thumbs up
Thanks for posting the news!
Old Dec 10, 2003 | 08:13 PM
blownlightning's Avatar
87 bronco
does anyone know if the 89 5.0 h.o. SEFI harness is compatible with the bronco haress (headlights, dash wiring etc.)? all i really want to know is if the connectors are the same, or what i have to do to make it work. also i will be using the computer from the 89 lx, and if i do i will leave the c6 if not i was thinking about getting an AOD and computer because the 89 computer is 5 speed. plus i think the extra gear will help. the truck is an 87 stock 5.0. w/c6 trans. any info will help.
