ABS Light & Parking Brake Light On...
Old Sep 29, 2003 | 03:58 PM
smooth_talker23's Avatar
Question ABS Light & Parking Brake Light On...
I need some advise. Over the weekend I started my truck and the ABS light and parking brake light came on. I drove to the end of the block with no problems and restarted the truck but the lights stayed on. After making a few stops all of a sudden I go to brake and the brake pedal goes all the way to the floor. I'm going to dive into the problem tonight but wanted to see if anyone had any thoughts....
Old Sep 29, 2003 | 06:51 PM
Ford4ever's Avatar
Probably low on fluid, check for leaks.
-Jon
Old Sep 30, 2003 | 10:22 AM
ccnseven's Avatar
I know this sounds weird but I drove my truck for a year with the abs light on and couldn't figure it out, then I noticed a wire hanging from the rear end and took a look. Figured out where it had been and re connected it, my abs light quit comming on. Learned later that the vss on the rear end is also connected to the abs light and speedometer.
Yours sound low on fluid though
Old Sep 30, 2003 | 11:57 AM
Smile
Thanks for input guys...
Old Sep 30, 2003 | 12:03 PM
nditech's Avatar
I had a 95 with the same problem turned out to be a short between on of the sensors. took the dealer a whole day to find it and fix it.
Old Oct 22, 2003 | 12:13 AM
fivept0's Avatar
Check the rear wheel cylinders for leaks. If one of these is leaking it will cause a loss of fluid, which will trigger the lights.
Old Oct 22, 2003 | 11:27 PM
dave186's Avatar
My truck has that same problem, the slowly leaking wheel cylinder eventually causes the fluid to get low enough to cause the abs and brake lights to come on.
