vin decoder for 94 f350
Old Aug 24, 2003 | 05:54 PM
wicked5ltr's Avatar
Question vin decoder for 94 f350
Does anyone know where I can find a vin decoder and door sticker decoder online for a 94 f350? my wife just bought me a crewcab 4x4 and i'm out to sea but want to learn as much about it as i can, such as gears, etc. Thanks for any help, Tim
Old Aug 25, 2003 | 12:54 AM
PKRWUD's Avatar
I don't know where online, but I have the factory service information, and can decode your vin and your drivers side door jamb sticker info (i forgot what the damn sticker is called, but you know what i'm talking about). Post all the info, and I'll decipher it for you.
Take care,
~Chris
Old Aug 25, 2003 | 03:07 AM
wicked5ltr's Avatar
vin: 2FTJW36G8RCA24674
her email was confusing, but this is what she told me:
axle C9,
body G6D,
trans E,
springs 84F,
Type GVW- W361 ( i'm not sure if she read this one right, but if it makes sense to you, let me know)
Thanks for your help, my main question is regarding axle (ratio and limited slip or open) trans would be nice too.
94 f350 crewcab 4x4
Thanks for all your help, Tim
Old Aug 25, 2003 | 07:25 PM
PKRWUD's Avatar
2FTJW36G8RCA24674
2FT: Complete truck, manufactured in Canada
J: GVWR Range: 9,001 - 10,000 pounds
W36: F350, 4x4, Super or Crew Cab
G: 7.5L 460ci Gasoline V8 built by Ford
8: check digit
R: 1994 Model
C: Assembly Plant: Ontario Truck, Oakville, Ontario
Axle:
C9: 3.55, 6250 lbs capacity, Rear is limited slip, front is not.
Body:
G (seats): Bodycloth Split Bench Seat
6 (trim color): Grey Opal
D (cab/bed): Crew Cab/Styleside
Trans:
E: Automatic E4OD
Springs: (these codes just give you the part numbers)
Type GVW:
W361: GVWR: 9200 lbs., 168" Wheelbase
Take care,
~Chris
Old Aug 25, 2003 | 08:57 PM
wicked5ltr's Avatar
Thumbs up
PKRWUD,
Thanks for all the info, my only concern now is that the owner told my wife that it had 4.11's, so i will check it out when i get home, everything else checks out good though. What source are you using to get this info? Thanks again, Tim
Old Aug 26, 2003 | 01:22 AM
PKRWUD's Avatar
Ford Factory Service Manual.
The axle code for 4.10's for that truck would be C5 for limited slip, and 35 for open.
