Engine cutting out
Old Mar 3, 2003 | 11:53 PM
MXZX1100cc's Avatar
Engine cutting out
Ok my truck is a 93 F-150 with a 302 in it. Under acceleration or in over drive my truck will just cut out. It will only cut out for a brief second but then it will do it over and over again. I'am thinking its the coil going bad, but not positive. And it just had a tune up not more than 5,000 miles ago. Any info would be great thanks.
Old Mar 4, 2003 | 07:54 AM
ccnseven's Avatar
Checked you're fuel filter lately? Could also be the coil you mentioned.
Old Mar 5, 2003 | 04:20 AM
MXZX1100cc's Avatar
Yes the fuel filter is new to, when Ford did the recall on the fuel regulator they also did change the filter.
Old Mar 5, 2003 | 05:05 AM
Shawn93's Avatar
The recall was a couple years ago.they replaced the fuel pressure regulator and the fuel tank check valve.there was a problem with the fuel from the tank goin into the other tank causin overflow.check it out here http://www.alldata.com/TSB/20/93201601.html
