Low Gas Mileage
Old Feb 13, 2003 | 10:51 PM
UrbanCowboy's Avatar
Low Gas Mileage
For whatever reason, I've started getting abnormally low gas mileage. Can you guys make some suggestions on components that can cause this effect when they need replaced? I dropped from like 14-15mph to 10mph. thanks
Old Feb 13, 2003 | 11:01 PM
SPROCKET_X's Avatar
i recently found out clogged cats will.
Old Feb 14, 2003 | 12:25 AM
StrangeRanger's Avatar
O2 sensors, Engine Coolant Temperature sensor.
Old Feb 14, 2003 | 12:43 AM
That's right. A few weeks ago I had a friend's father tell me it sounded like my Cat was bad. I bet that might be the problem. I think my sensors should be okay, but I might check into that also. Any other suggestions guys? Thanks!!
Old Feb 14, 2003 | 07:38 AM
Macgyver's Avatar
has your idle increased or decreased??? decrease would suggest a clogged cat . increase would suggest leaking intake gaskets . i just got done replacing ALL the gaskets in my motor as i had a high idle and leaking oil all over . easy way to cheak the gaskets is to spray some starter fluid around the gaskets . if your idle increases then you got a bad gasket . ( and yes my gas mileage sucked big time )
