82 F-150 351w
Old Jan 23, 2003 | 10:33 PM
rb_wilson's Avatar
Question 82 F-150 351w
I have a 1982 F-150 4X4 with a 351W The engin has been rebuilt with a towing cam and it is bored 30 over. The normal intake manfoild has been replaced with a 4Bll intake. The problem is the truck get about 6 miles per gallon. I think that it has the worng carb. on it. (or am I just Crazy) I also having some choke problems. I NEED HELP!!!!!!!!!!!
PLEASE
I would like to know what CFM to get plus what brand would be best.
Old Jan 24, 2003 | 11:15 PM
Ford4ever's Avatar
If you go to the Holly or Edelbrock website you can send an email to the technical department with your engine specs and they will recommend a carb. Personally i would go with a Holly truck avenger or street avenger carb because they are really simple to tune. If i had to guess i would say a 650cfm carb would be about right for your engine. I'm building a 351w right now that will put out about 500hp and 550lbft torque and i'm only using a 750cfm on it.
Do you know what carb is on it now? Maybe it just needs to be adjusted and have the choke fixed?
-Jon
Old Jan 25, 2003 | 11:15 AM
rb_wilson's Avatar
Question
Jon,
I am not sure what kind of carb is on the truck. I have looked for an I.D. tag and someone has removed it. I have even look for the manufacturer like ford or carter but with no luck. I was thinking about just a strait Edelbrock 500cfm 4 bll.
Do you think that the 500 cfm will be a good choice.
Brandon
