radiator, leaking, fix or replace???
Old Dec 16, 2002 | 08:56 PM
bw99's Avatar
93 f-50, the ol plastic radiator is leaking out both sides, I had a price of fixing it for 60.00 or replacement for 160.00 I just wondered if you guys had any luck repairing those things.
Thanks.
Old Dec 16, 2002 | 10:24 PM
Yankee7985's Avatar
If it was my truck, I would bite the bullet and replace the radiator. The plastic on the radiators usually gets brittle and tends to crack easily when they get old. Consider the age of the radiator, I would also be concerned about the radiator core and its condition.
Old Dec 16, 2002 | 10:33 PM
Donate54's Avatar
i had this happen to my truck too and i just ended up replacing the whole radiator with a steel unit (i went ahead and put ina bigger one than factory, and it runs much cooler now, especially when driving with a load).
Old Dec 16, 2002 | 11:26 PM
KAS300's Avatar
You say its leaking on the sides, do you mean where the tankss are crimped on? I'd just replace it. I don't think I'd trust a repaired radiator, I'd just be nervous about it.
Old Dec 17, 2002 | 10:27 AM
hapynzap's Avatar
I'd go for a new heavy duty one
Old Dec 17, 2002 | 01:32 PM
PKRWUD's Avatar
Replace it.
Old Dec 17, 2002 | 02:22 PM
signmaster's Avatar
Mine recently started seeping on the input side. I took it out and had new seals put in and recrimped. A new one is more $$$ but less wait. In my case it didn't matter as I had another vehicle to use.
The shop I took mine to inspects it with the tanks off, and if it's bad they will recommend a new one. Mine was flowing fine, and no obstruction problems, so I chose to just redo the seals.
