What strap do you use?
I use a strap that I got at a heavy equipment store. 4"x30ft. Yanked out a couple guys with it, plus a few trees with no problem.
http://www.buy.com/pr/product.aspx?s...lerid=33250433
This 4-inch X 30-foot extra heavy-duty 40,000 lb capacity cargo strap is ideal for towing and freeing trucks or disabled vehicles from mud, sand or snow, holding up to 40,000 lbs. This strap features double twisted ends that fit right onto tow hooks. Tough terylene webbing sustains wear and tear.
I use an ARB recovery strap rated around 24k lbs IIRC.
make sure to keep it clean, a dirty strap won't last as long.
My friend made his strap out of 3 climbing ropes and braided them together. Stretches like crazy and does the job very well.
it might be more of an issue of what size trap you use not what brand. also how it is used. alot of people hook up and want to floor it to yank you out when most the time all you need is a little tug. a 2" strap is ok for a 4 quad but a fullsize truck needs a 3" or 4" wide strap. keep it clean and out of the sun.
I forgot to mention, make sure to buy a recovery strap not a tow strap.
recovery strap = stretches
tow strap = no stretch
I just got 125 ft of 5/16 winch line so no more recovery strap for me
keep the strap diameter between 2-4 inches. if its too small itll snap obviously, too big and you wont have enough power when pulling to making it stretch and retract, thus killing the major usefulness of a recovery strap (****** rope) by allowing it to help pull. never use anything with metal on it, because when it goes flying due to breaking (and a strap WILL break eventually) your going to have a missile on your hands coming at something very fast.
My ****** rope is 2" diameter, 20,000 lbs rated. ive had it for 4 years and put it through hard use and it has yet to break on me(going bumper to bumper with my frame buried truck and flooring a 4x4 v8 tahoe multiple times until it came out). take care of them, wash them off, keep them away from the sun and sharp/abrasive things.
I have a 4" 40000 lb tow strap designed for tractors and D-rings that I got from a local farm supply store. It's doesn't have any play in it, so I just have to make sure its tight before I start pulling/get pulled. I always keep it in my toolbox so the weather doesn't compromise it's strength. I went through several smaller and weaker straps before I finally got this one.
Pricey but they work great and should last a very long time if taken care of
http://www.bubbarope.com/professional-recovery-rope
Same, mine has a little give though, it works extremely well, I've actually used it to the point where I should probably replace it. Ive used it to haul out a bobcat a few times, a tractor a few times, my buddys plow truck (that was the most entertaining), but it gets the most amount of use in the winter time, its like people forget how to drive in the snow...every year...
I am on my 2nd 3" x 20' Keeper 20K lb strap. It is a carryover from my Ranger and I haven't had to replace it yet. It is looking kind of gnarly though, might be time to get a new one. Might grab the Smittybuilt 3" x 30' 30K lb strap to get some extra distance between me and the stuck vehicle.. At least I try to not be that guy...
