Looking for some advice
If you search this topic you will get a bunch of stuff. But heres a quick few...
Mud tires
Tow strap (for when you get stuck)
And a friend with a 4x4 to get you unstuck
If your serious and have the money...
Rear locker or LS
Lift
Winch
Momentum is your friend, mud all in your engine- not so much.
Mud tires
Rear locker or LS
Lift
Winch
Mud tires
Rear locker or LS
Lift
Winch
Mud tires
Rear locker or LS
Lift
Winch
Mud tires
Rear locker or LS
Lift
Winch
Mud tires
Rear locker or LS
Lift
Winch
1.Mud tires will be a necessity with a 2wd to be able to do anything at all in the mud
2. Go with a chain, not a strap. I've broken so many straps, and never broke a chain
3.Definitely have somebody to get you out. With a 2wd, you WILL get stuck. Often. Regardless of what tires you have
4. A locker would be a very good idea, and so would a winch. Warn just came out with the new VR series with 8,000 10,000 or 12,000lb models that aren't near as expensive as their other models. I plan on getting the VR 10,000
2wd and mud riding is really hard to make work.
if you value your life, use a strap. get a quality strap, if you have access get one from the ship yard. when a chain snaps, something else will get damaged whether it be a grille, windshield, person behind the windshield.
http://www.youtube.com/watch?v=845cxykfDns
http://www.offroaders.com/tech/Tow_Straps.htm
id but a cheap pos older f150 ie 80-96 4x4 why beat up a good 3 year old truck get an old truck easy and cheap to get parts plust u dont have to tag or insure get to tow bar and tow it to the trails and wheel drive it up hook it up and go home
