4X4 Speeds
Old Mar 14, 2011 | 11:27 AM
jrock24's Avatar
Originally Posted by panda24619
i dont mean 55 actual. i mean 55 read on the speedo. so then you would be going what? 23 actual? whats the low range? 2.37 or something like that.
The low range gear ratio does not change the speedometer. Even 23 in 4 low would probably break something.
Old Mar 17, 2011 | 02:52 PM
08stx4x4's Avatar
You'd be lucky if you could hit 25 in 4LO since chances are it won't leave first gear. Also, at that speed you would be bumping off the rev limiter on your engine.
As for 4HI you're not supposed to switch in or out above 55MPH. Once you're locked in though you can go as fast as you want, the tcase will hold up.
Remember, the Transfer Case is always turning whether you're locked in 2WD, 4HI, or 4LO. When you switch to 4HI or 4LO it just engages the rest of the gears to turn the front drive shaft/axle and locks the front hubs.
Old Mar 19, 2011 | 10:04 AM
JMC's Avatar
JMC
25 Year Member
The fastest I have ever been in 4Lo is 62mph. I just wanted to see how fast the truck would go. There are no speed limiting factors except ones abilities to drive.
Old Mar 19, 2011 | 01:33 PM
panda24619's Avatar
see i knew you could drive fast in 4lo. and i have been in 4th gear in 4lo. i was flying threw this trail. i forgot i was in 4lo.
Old Mar 29, 2011 | 09:45 PM
04heritagef150's Avatar
I think that the 4wd automatically disengages when you got over 45 mph (at least in 4HI)
Old Mar 29, 2011 | 10:00 PM
JMC's Avatar
JMC
25 Year Member
No. The BW 4406 is a part time transfer case. Unless you have the AWD version it is either in 4x4 or in 4x2. The gears shift and lock in place and they stay engaged unless you shift out of 4x4.
Old Mar 30, 2011 | 12:19 AM
06yz250f's Avatar
stupidity of this thread is great.....
Old Apr 16, 2011 | 01:41 PM
Pickup Man's Avatar
[QUOTE=mustangjonny84;4488408]Not out of concern for my transfer case...just the safety of the rest of my truck.
QUOTE]
Don't forget your own ***!
Snow is fine, screw going 70 on ice! You all are sounding crazy, lol!
Also, yeah, first gear in 4lo is slow, but you can just throw it in D and make some pretty good speeds if you wanted. In winter, though, 4hi will be fine, except on ice, then you really don't want to be making that kind of speed anyway.
