tow hook flag mount
lol thinking something to were i can use again with out redoing.. ha you should have saw how my flag was holding up last sat at bundy hill.. didnt know till last min i was going. so fabd a quick mount 10 mins broke but still held to tow hook used wire around bumper and to grill.. it was funny.
I dont know anything about ORV flags since pretty much all land in Texas is private but here is how I mounted my USA flag for Wheelers for the Wounded last month. I doubt the flag is this big. Plus I doubt you want to drill holes for just a flag mount.
Has to be in the front.. might not be a bad idea tho..
ok, I fabbed a piece of 1.5" angle iron. Took off my right front tow hook. Algin the angle with the holes of the tow hook, drilled to match. notched the piece so that when mounted to the frame it will make the flag slightly angled forward. that way when driving the wind will not force the the flag back. then drilled a hole larger than the flag stud and welded the nut to the bottom of the angle iron. when I head for the dunes screw in the flag hand tight and bam Mr. DNR is happy
Flat steel 1/4 inch thick by 1 inch wide by 6 inches long and a muffler clamp. Drill a hole at one end for the flag and two at the other end for the muffler clamp. The muffler clamp goes around the tow hook and into the two holes and gets bolted tight. The flag at the other end. Most shops at Silver Lake sell them.
