wide tires
Old Apr 20, 2010 | 05:52 PM
Fordfan4life199's Avatar
wide tires
I am lookin to get wider tires later on after mine now wear out. How wide of a rim will i need for a 14.5"-15.5" wide tires?
Old Apr 20, 2010 | 06:36 PM
str8t six's Avatar
i think the widest they make for our trucks are 10" wide wheels. they used to make some 12" but they are discontinued.
so i think you are stuck with 10" wheels.
how tall of a tire are you looking at?
Old Apr 20, 2010 | 07:50 PM
thanks, either 35s-37s
Old Apr 20, 2010 | 09:12 PM
Expyon37s's Avatar
on my 97 f150 i had 38x15.5r16.5 swamper radial tsls on a 9.75" wide rim... now on my expy running 37x13.5r16 xtreme ats on a 10" wide rim... f150 had 6" fabtech + 3" body lift n torsion bars cranked... expy has 6" fabtech + 3" bl + 2" coil spacer.... if that helps u out at all
Old Apr 20, 2010 | 09:20 PM
thanks man yea that helps some.
Old Apr 20, 2010 | 09:44 PM
str8t six's Avatar
U will be fine man. There are tons of guys running those size tires on 10" wide rims. I will be too eventually! Haha
Old Apr 21, 2010 | 09:36 AM
minimonster17's Avatar
Personally, 14.50 is as wide as I would run. 15.50 will rub too much. (14.50 will rub a little too.)
Old Apr 21, 2010 | 05:50 PM
yea 15.5 is prudy wide. 14.5s will do just as good.
Old Apr 22, 2010 | 01:06 AM
bconnaway's Avatar
whats the biggest tire you could throw on stock rims? ive been looking around trying to find that answer, but noone really seems to say since everyone with bigger tires goes with aftermarket rims...
Old Apr 22, 2010 | 01:46 AM
4.2trimble's Avatar
You can put up to a 12.5" wide tire on stock wheels. Tire diameter will not matter. I had 36's on my stock wheels. As long as you don't go over 12.5" wide you can go as tall as you want.
Old Apr 22, 2010 | 09:28 AM
karnak's Avatar
Registered User
im about to go up to 35s once i get my body lift, will i need to re-gear? i have 3.55 gears right now
Old Apr 22, 2010 | 09:58 AM
4.2trimble's Avatar
it would definitely help out alot.
4.56's would be good
Old Apr 22, 2010 | 10:52 AM
karnak's Avatar
Registered User
How much would that run me roughly?
Old Apr 22, 2010 | 12:21 PM
b2therad's Avatar
4x4? $1100-1400
2wd? $600-700
Old Apr 22, 2010 | 04:06 PM
str8t six's Avatar
I got a quote for 1500 for my truck.
Is your truck a 5.4?
