Question about pulling out!!!
Old Feb 18, 2008 | 02:43 PM
CRF250rider1000's Avatar
Originally Posted by jbracket
I have been using a chain to pull people out, but i never jerk it or anything like that. I have been trying to find a nice tow strap that i can yank and jerk with it. I need advice on what to get. If anyone can post me a link to a good strap that would be greatly apperciated.
Go down to TSC and pick out what strength you want I have a 30,000lb recovery strap that is 30ft long and 3" wide I think
Old Feb 18, 2008 | 03:43 PM
jbracket's Avatar
ok, thank you very much
Old Feb 19, 2008 | 06:40 PM
MonteCarlo31's Avatar
bring that thing out to lakeland this weekend and we can go over some recovery ideas.
Old Feb 19, 2008 | 08:28 PM
minimonster17's Avatar
montecarlo: is lakeland where you are located?
Old Feb 20, 2008 | 10:57 AM
Sackett's Avatar
I too have a firehose, but have never used it due to the uncertainty of it's strength. I bought a 4" 40K lb ****** strap from Northern Tool for ~$40.
Never try to tow or "unstick" someone by attaching to your tow ball. Think of that tow ball acting as a 2lb cannon ball that will go through anything in it's path should it break.
As others have said, get a shackle that will attach to a towbar fitted into your reciever hitch. I got mine from 4Wheel Parts for about $35.
Old Feb 20, 2008 | 08:40 PM
no, wesley chapel here. Mud pit in lakeland.
Old Feb 20, 2008 | 09:21 PM
me07xlt's Avatar
Shackle Selection
One thing to keep in mind is the load rating of the shackle you use to attach the strap to the vehicle. There are a lot of low quality cheap ones out there at home depot and lowes. Think about the load a 30,000 lb strap will put on it with a good ******. You really don't want a 10,000 lb shackle exploding and becoming a missle.
Old Feb 20, 2008 | 09:23 PM
KingRanch Glenn's Avatar
Put the end of your tow strap into your receiver and put the pin through the strap eye. Toss the strap into your bed. If you need it the strap is ready to go.
This works very well. No ball to worry about, no d-ring to open up, no extra receiver accessory to buy.
Old Feb 20, 2008 | 09:57 PM
Mikestyger1's Avatar
Talking
THat sounds pretty simple and effective! THink that would work with the firehose? I have had good luck with the firehose and really like the way it has worked for me so far. Definatley will not be tieing it around the ball anymore thanks to the visuals I've gotten from the comments on here.
Old Feb 20, 2008 | 09:59 PM
I lived in Bridgewater for 2 years and finally bought a house in Tampa now. Is the traffic out in WC any better yet? It was one of the main reasons I got out. Working at Busch Gardens it was a lengthy drive waiting in traffic on SR 54.
Old Feb 22, 2008 | 07:36 PM
JD.'s Avatar
JD.
Give us some specifics on the hose, is it LDH (5"), 3", 2-1/2, 1-3/4 ? As a FF I frown apon using hose as a strap although I have seen it done. You can pick up quality straps cheap sometimes
20,000 pound
30,000 pound
Old Feb 26, 2008 | 02:34 PM
dirt_bound's Avatar
ya dont pull from ball unless u have a huge ball mount i was using a standard class 3 ball mount to snap a chevy out and about the third attempt it felt like i ripped the bumper off but it was the ball and the tounge that snapped claen off and it went through the back window of there truck with out shattering the window clean hole and the graze the kids cheek now i have a hitch that is solid and has a max tound weight of 20,000 lbs and a breaking weight of 27000lbs....i also go out to this place called rancho out by lakeland if anyone has ever been there from this forum
Old Feb 26, 2008 | 09:03 PM
02XLT4X4's Avatar
Originally Posted by Boxerguy1989
Yea it's been said before but when you actually see a 2"ball snap and become a 2" bullet it becomes pretty clear that spending a few extra $$ is the better choice.
Don't pull from a ball no matter what your actual ball mount is, they are not made for it and can fail with deadly results.
