One stuck truck
https://www.usedconnection.com/FileS...3/302333-3.jpg
Keeping one of these on hand will solve that problem
Originally Posted by CRF250rider1000
Psh I could tow it
JK I would need AT LEAST an F450 dually to be remotely close to what tow vehicle that thing needs
Ummm........ok
You need to up your specs from the F450 just a tad if you want to have a PRAYER to pull that. There is a reason its loaded on an RGN in the pic. It would however either pull out a stuck vehicle or pull it in half doing it.
HD Strap
This is what I use, I've yet to not yank someone out on a 2nd pull, the stored energy in this is huge if you have a truck that weights enough. I've seen little toyotas on 37s pull out sunk superduties on 38s and more with one yank. It's all about using kinetic energy. Make the vehicle work for you, not against you.
Originally Posted by MonteCarlo31
HD Strap
That thing is expensive. I got my strap for much much less. I've only had to use it once, so maybe if I was a hardcore off roader it might be more economically feasible.
Originally Posted by c0ckac0la
$272
