Well this worked well...
Old Dec 5, 2007 | 07:06 PM
  #46
CRF250rider1000's Avatar
Tractor supply has Clevises pretty cheap. Just stick them through the hole in your receiver
Old Dec 6, 2007 | 02:58 AM
  #47
Pheonixx's Avatar
+1 for TSC (tractor supplly co.)
i work for TSC, im still amazed as some of the stuff we sell.
yes chains CAN be safe if used right. i wish i had a pic of the chain i made a few years back for pulling people out. i added extra links hanging down off the other links so when i hooked up there was a "weight link" every 12 inches. the chain did finally break, but it simply fell down instead of launching.
Old Dec 6, 2007 | 11:38 AM
  #48
02XLT4X4's Avatar
Originally Posted by powerstroke73
Completely different applications
Chains are only to be used in a static load application. Thats why with heavy equipment it is common to see them as they are going at slow speeds and not trying to "******" a vehicle. Its the shock loading that kills the chain. When you tractor pull you pull the chain tight to start with right? If you didn't you'd stand a chance of breaking the hook or the chain.
For pulling out a truck stuck in the mud when you don't have a large vehicle is to use a strap. While yes they do stretch when you pull, but its by design. It not only cushions the pull, but it also absorbs the energy and then releases it after a short time. That release in energy helps to unstick the vehicle.
I ease into it when I start, the same theory has worked find when recovering vehicles or even tractors as well. Only problem is you have to have enough beef to tug it outright, without getting a run at it, which can hurt things no matter what you are using.
Old Dec 7, 2007 | 08:23 PM
  #49
alsupercab's Avatar
im going to throw my .02 in on the whole chain method. If you use a line weight you dont have anything to worry about. If metal is so dangerous, then why is EVERY winch on the market come standard with STEEL cable? Because with a line weight it is perfectly safe.
Old Dec 7, 2007 | 11:12 PM
  #50
squirtbottle09's Avatar
There is a big difference in between cable being snapped, and chain being snapped. You shouldnt snap either, but cable will last longer. AND, line weights cab be very dangerous as well. Even putting a blanket or tarp with weights isnt very smart unless doing a slow pull.
