max tire size
Old May 28, 2007 | 02:02 PM
renegade1979's Avatar
max tire size
What is the maximum tire size for a stock sport f-150 4.6? I like to go where stock trucks can and not much more but want bigger tires. Oh yeah, it is awfully embarassing being pulled out by a colarado like last night!!
Old May 28, 2007 | 03:57 PM
powerstroke73's Avatar
If its on the 2000 you list in your profile then a 285/75/16 (or 285/70/17) is the largest you can go on the stock 7" rims. You won't have any rubbing issues. You can go up to a 305/70/16 on stock rims, but it'll wear the tires prematurely and will try and rub. 16x8 wheels will make the tires wear better, but will rub worse. You can put a 3" body lift on and fit up to a 315/75/16 tire even on a 10" wheel. That will require some minor trimming (5 min and hard to even see it). On 16x8 wheels you wouldn't have any rubbing. I ran all those setups but the 305s on my old 97 F150.
Old May 28, 2007 | 04:09 PM
dubbass33's Avatar
i'd also like to know what size tires i can get on a 1997 f150 4x4 Off Road without rubbing and enough suspension travel.
Old May 28, 2007 | 04:15 PM
Kevin24's Avatar
I would crank the t-bars and do 305s
cheack this thread out guys,looks awesome and a ton of flex on stock suspension!!!
https://www.f150online.com/forums/sh...d.php?t=282744
Old May 28, 2007 | 05:06 PM
Impact9's Avatar
Jump into the tires and wheels forum. Wandel is the site tire guru. Plus you'll get many more responses there from other experts.
